Hi, I have a balance 305 and I want to know if there are any issues in upgrading from 6.1.0 build 2863 to 6.3.4. I plan on saving the configuration file. Will that restore ok to the new firmware(6.3.4)? I’ve heard others say they with their router they’ve had to get an upgrade key. Is that the case with my upgrade? Thank you
You can upgrade no problem and your configuration will stay intact but it is still a good idea to save the configuration first.
