Is it possible to upgrade Balance 30 LTE routers that they can have SpeedFusion Hot Failover or SpeedFusion Bonding?
Or how can I configure that if WAN1 goes down the Cellular LTE connection builds up the PepVPN?
regards
Robert
regards
Robert
Hi Robert,
In the PepVPN profile just select the Cellular LTE connection as Priority 2 and the tunnel will rebuild if WAN1 fails.
