for the same co-housing project described here we’ve reached the maximum supported VLANs. which is 16!?
Are there plans to increase this amount?
The Balance 20x seemed to be great for the project, which houses 12-15 tenants for which we need 20VLAN.
4 general purpose VLANs (security, IoT, guest, community) and 12-15 tenant VLANs.
Sad to see the Balance 20x isn’t up for the task of managing 20 VLAN as the next step up is the Balance Two
The balance two has two major downsides: It does not have cellular (for remote troubleshooting when the wan is down) and it comes at nearly 3 times the cost.
A slight increase to like 25-30 supported VLAN would be a welcome sight here at our end.
