Quick Question: I just upgraded my Balance 20 to a new Balance One, I just want to know if I can backup the config from the 20 and transfer it to One?
Otherwise, this Balance One runs circles around the Balance 20.
We may be able to convert the config for you manually if you open a support ticket here:
http://cs.peplink.com/contact/support/
Otherwise, it may be easier to just manually rebuild it yourself.
Nice throughput BTW.
I just found out conversion is not possible and you would need to rebuild it yourself…
Well this might take a while. Thanks Tim.
