Balance 20 - Power On, Solid Red Status
Hi
I have a Balance 20 hardly, if ever, used.
I powered it up the other day and I believe it was running on v5.4 firmware. I was able to access the web admin pages normally. I tried uploading firmware v6.3 via the web admin page. This activity just caused the device to hang with a solid red status LED. I was able to reset to factory setting via the reset button.
Then I tried the same method, manual firmware upload, of v6.1. The device also hung and after 20-30 min.
I tried factory reset with no luck, and then I unplugged the device.
At this point,
  • the power LED comes on solid green and the status LED stays solid red.
  • Trying factory reset does nothing.
  • accessing via 192.168.1.1, no luck
  • nmap shows the device at this IP ‘up’ but with no open ports.
What else can I do?
Peter
Please open a support ticket here for the team to further investigate.
Thank You
