I’m about to get a b20 on ebay and I thought I’d check first if all b20s are eligible to 6.x? (I’m aware of the fact that that i’ll need to pay for the warranty extension for that).
Or are there special date codes or serial numbers that are eligible?
Thanks for the quick answer. My question was not clear, sorry. I meant I’m about to buy a **used **b20 on ebay… And was wondering if whatever its age it was going to be upgradable to 6.x?
The only model that would not be upgradeable is the Balance 20L. This is a very old unit that was in a plastic enclosure. If you want to confirm the serial number we can double check it.
