Can Pepwave MAX give access to AT Command .
We don’t support this at the moment. Can you share the reason you need this?
Yes,
My Client is trying to test the device with “Rohde & Schwartz CMW-500”, it is Wideband Radio Communication Tester that uses AT command for test RF devices (among other test) , PEPWave is not supporting uses of AT command therefor they could test with this equipment.
Hello David,
Thank you for the feedback. I will move this to feature request for better exposure.
