PL 20 allows to assign multiple public IPs to one of the WAN interfaces… or both.
Now, can I use those IPs in round-robin fashion for outgoing traffic?
The weighted balance algorithm with equal weights to each WAN can be used to round robin outbound sessions.
Ron,
So the outbound sessions will use all range of assigned public IPs as their source?
Should this be done in “NAT Mapping” section instead?
It will use the WAN Interface IP by default. If you need a specific additional public to be used for outbound this would need to be defined via a NAT Mapping > Outbound Mapping.
