AP Pro vs Device Connector IP67
Can we connect 10 ethernet devices with 10 AP Pro using WDS to another AP Pro which is connected to backhaul?
What is the difference between AP Pro and Device Connector IP67? If possible we want to use AP Pro instead of Device Connector IP67 because of the huge price advantage.
Thanks.
  1. ​Can we connect 10 ethernet devices with 10 AP Pro using WDS to another AP Pro which is connected to backhaul?
    You can achieve like this:-
    10 x Ethernet devices <–Wired–> 10 x Device Connector <–Wireless–> AP Pro.
Basically AP Pro is an outdoor AP and Device Connector IP67 is an outdoor repeater. Device Connector is a complete wireless network extension solution with advanced TruePower technology that keeps signals clean, clear, and strong from start to finish.
