Dear Guys,
What would be the practical coverage on open areas for AP One X ? I Mean for connecting regular clients like tablets , smart phones , laptops not using a powerful receiver on the client side.
waiting your reply,
Thanks and regards,
Dear Guys,
waiting your reply,
Thanks and regards,
Any Update ?
This is difficult to put an exact number on because there are lots of variables. It will easily go several hundred feet, but the client devices will have much lower output power and this will affect overall performance.
Dear Tim ,
Could you give me an approximate number according to the experimental projects ? this is the most common question customers ask when planning a wireless network.
Thank you
