I have a question about the AP One InWall.
Need the AP a DC adapter or with the switch’s PoE is enough?
It’s that I don’t understand how an AP Poe can have a output Poe, I find it strange.
Thank You.
Thank You.
This is depend the power output require to power up the end device.
Recommendation:
Power source 802.3at --Power In–> AP One In-Wall --Power Out–> 802.3af
If end device require more power, you can also consider to use “48V DC Connector” for the power input:
Power source 48V DC Connector --Power In–> AP One In-Wall --Power Out–> 802.3af
Thank You
