I just installed the AP One AX Lite vis Ethernet and the web portal from my Max Transit duo.
I am trying to log into the AP One to turn off the lights however The default password does not work and I do not see any feature from my Max transit duo to accomplish this.
Did the web portal from my Max Transit change the passwords for the AP One? If so what to or how do I find it?
I did not change anything nor log into the AP One when installing it just did the install form my max Transit portal.
