I just installed my AP One 300M and took over management functions with the Balance 20. I can change the settings but none of the data shows up in the dashboard. By data, I mean it shows 0 clients connected, no SSID’s, no data usage. I’ve tried unmanaging / remanaging multiple times and powercycled both pieces of equipment. The data shows up fine if I unmanage and log into the WAP directly.
The AP One is on firmware 3.4.1 but someone else in the forums said there was a 3.5.2 build 1537 out for this device. I couldn’t find it. The Balance is on 6.3.1 build 3138.
The firmware update looks like it’s given me another problem - the guest network no longer works. My primary SSID on VLAN 0 works fine. The guest SSID on VLAN 4 does not connect.
The wireless connection is negotiated, but no traffic will pass. I can’t even pull a DHCP address. I’ve tried deleting and recreating the guest SSID and powercycling both devices.
