I am setting up a guest portal SSID and I see two settings that I am not clear on. Under the “Web Portal Login” option of a newly created SSID, I see “Pass-through Domains/IPs” and “Pass-through Client IPs” - what are these settings for? I cant find anything on the manual. Thanks!
Possible to let us know the firmware version using for your AP One 300M ?
“Allowed Domains/IPs”
- Destination domains or IPs listed will be allowed access by guest user without go through Captive Portal login
“Allowed Client IPs”
- Client IP listed will be bypassed for Captive-portal login
Thank You
Got it! Thank you so much!
