Any benefit to 4 antennas for MAX BR1 Mini?
I have a Peplink 42G antenna on the roof of my RV that was using with a T-Mobile 5g Gateway which has four antenna ports. I am now using it exclusively with my MAX BR1 Mini which only has two cellular antenna ports. Would there be any benefit from combining the four antenna connections? If so, what type of device would I use to combine them? It seems a simple splitter would not be the correct option.
Thanks for any advice.
Cheers,
Jason
Just use two of them and leave the other two unconnected. That’s a great antenna – you need a MAX Pro 5G to go along with it! :<) :<)
That’s what I’ve done for now. It seems a shame to “waste” the other two connections but if there’s no benefit, I have a saying for that. “The most efficient way to do the unnecessary is not to do it at all.”
