Antenna Needed?
What antenna should I use with the MAX-BR1-MINI-LTEA-W-T
Are you looking for something for a specific use case like an outdoor antenna or vehicle mount?
Do you need to connect all of the devices radios to it (Cell, GPS and WiFi) or just some of them?
A little bit more info about your specific needs here may help people to make a more useful suggestion, but as it stands if you wanted a place to start looking the Peplink Mobility antennas are pretty decent.
If you just want an all in one dome sort of thing for various mounting options and that connects all of the radios in your Mini you’d need something like the Mobility 22G and just leave one of the WiFi cables disconnected.
