Hi All,
after reading some topics here i still don’t understand the alternate between sim cards.
Lets say we are 3th off the month and i pick the 15th to alternate.
Does this mean from now 3th till the 15th it’s sim A,
and then from 15th till “when??” its simB.
Is this till the 15th the next month or till end of the month?
If it’s till the 15th of next month that just means every sim cards will be active for 30 days alternate.
What i would like, you could set every sim for like 15days so you have double data volume.
As the UI presents, it is a monthly switching mechanism between SIM A and SIM B. If you are concerned about the data volume, Bandwidth Allowance Monitor may fit your configuration.
Don’'t want to sound stupid, but just to be sure.
Then to me that means:
SIM B is working till end of that month, And SIm A starts working on the first of the next month, till the switch schedule time right?
Let’s take an example below when you set it as 00:00, 15th:
SIM A will be connected from today (6 June) until 23:59, 14th June.
Then it will switch to SIM B on 00:00 15th June and SIM B will continue to be used until 14th July.
On 00:00 15th July, it will be switched back to SIM A.
Hope this clear your doubts.
By the way, I filed your feature request of switching SIM card after using for 15 days. Engineering team will review it.
Thanks.
Thank you very much for the confirmation.
