The current ability to create a vlan and add it to a single port is useful, but since the peplink then operates untagged on that port is is limited in usefulness.
It would be very good to be able to actually link a TAGGED vlan to a single port
In Network > LAN > Port Settings, change the type from Access to Trunk and select your desired VLAN in the VLAN column drop down list. This allows 802.1q traffic for only the designated VLAN to traverse the port.
