All LED blinking
Hi i have a issue with my modem when i connect annrenna via LAN cable all LAN lights blinks in orange and other blinks in green.What can be the reason
Hi, as I see in the photo you have SIM Injector.
The Ethernet LED meaning is the following:
Right LED
  • Green – PoE enabled
  • OFF – PoE is disabled
    Left LED
  • Solid Orange – Port is connected without traffic
  • Blinking Orange – Data is transferring
  • OFF – Port is not connected
In case you see not as deribed above, then very likely your device is damaged. Please contact you reseller for RMA.
