In one test case, we have a sim card that’s deprioritized (capped throughput by tmobile) unless you use a vpn. If I’d like to direct all traffic over the SF Connect cloud connection, do I need to set an outbound policy for the any/any wan cellular? Also, since we’re using IP Passthrough, does that mean that the first dhclp client that gets the cellular wan IP will have it’s traffic will go over the SF Connect cloud?
Asking because I’m reading conflicting information between forum and manual around the all traffic question over cellular wan.
If you are going to use SFC then don’t use IP passthrough (your connection will use NAT via SFC anyway).
Then when you enable SFC go to outbound policy create a priority rule and set any source to any destination to go via SFC as P1 and Cellular WAN as P2.
thank you!
