All 4 Signal Strength Indicators Flashing at Once
Was trying to connect to a marina WiFi with the Pepwave Surf On-The-Go. System looked like it was going through the proper steps but int he end there was no internet and all four signal strength LED’s were flashing (about 1 sec period) at the same time. I tried both 2.4G and 5G radios. Same issue. I also tried a couple different AP’s at the marina but got same result. I performed a hardware reset to try again but no luck, same result.
Returned home and was able to link to my home network just fine. I have also used the device at other marinas with no problems.
I could not find anything in the manual on 4 simultaneously flashing lights nor in an internet search. Hoping someone can help.
Thank you!
Please open support ticket here for support team to check. We need logs from the device to check on the WIFI WAN connection issue.
Thank you!
