Advice on home setup
Hi everyone,
Been considering purchasing Peplink products for my home network. This is purely for home use… average 18-24 devices connected. (Apple products mostly, a couple of google devices and other IoTs).
Currently using an Asus RT-AC87u flashed with Merlin… I live in a 2 story townhome with a finished basement (so 3 floors). Total about 1867 sq ft. We’re 5 people in the home and most stream music and video. I also have VOIP.
My current router is on main level centrally located near the ceiling, and i can get solid WIFI throughout. It starts to drop off outside in yard.
My ISP rated speeds are 500 up and 20 down…
I used to run Sophos XG firewall on an old PC but found it difficult to maintain at times and problematic with streaming video on certain devices.
I was looking at a Balance One core with possibly 1 AP Lite. AP lite would go where my current router is located.
What I’m unsure of is the WIFI range of 1 AP and whether it’d be enough to cover my entire home (2nd floor and basement)
Any advice is greatly appreciated.
Hello @stego,
There are a lot of posts in the forum worth reading on this.
Two models for you to consider are:
We recommend that you talk with your Peplink supplier, they should be a Certified Peplink Partner.
Where are you are based will help determine who you should source your Peplink from?
You can use this link to find your nearest Certified Peplink Partners
https://www.peplink.com/peplink-certified-partners/
Happy to Help,
Marcus :slight_smile:
