Addtl Captive Portal option
I would like to submit a request for an additional captive portal option that would allow them to access the captive portal using an application.
Josephine
Technical support
Singlepoint
Can you elaborate more on your request? What application you are using and how you access the Captive Portal by using the application?
The customer is trying to build an application where the customer fill out a survey form before they are allowed to go online.
Josephine
You may want to check out our advertisement service. With advertisement service, your customers will need to complete a survey before they can access to the internet.
