Can you please add “Connecting using SIM X” to the “Connecting…” status screen while the Cellular connection is trying to establish the connection. This would help when both sim slots are populated in the case of the BR1 to know which SIM slot it is trying to connect to. It would also be nice if all of these messages should indicate which SIM Slot it is utilizing without having to click on Detail.
Thank You,
Eric
