Adding New Hotspot - Surf SOHO - password won't stick
Added a phone as hotspot - but the password won’t stick. Reverts to another password on a similar hotspot that does not have the same password. Does the Surf SOHO only recognize the first three of four characters?
Hi JackTheBearTexas,
Welcome to the forum.
If the SSIDs are different you shouldn’t run into any issues. Does each SSID have a profile setup or are you changing the profile to connect to each hotspot?
Now none of the hotspots connect. Before it died was connecting but no internet. Just spins. Did hard reset. SOHO is old. Maybe it has died.
Going to Best Buy to buy new router. I think my old SOHO is toast. Did reset. Wont connect to any of my three hot spots and now can’t connect via LAN to other computers on net work. I am sad
