Similar to how the cellular details are displayed locally.
Imei
Iccid
Please add starlink details in the local router ui
Starlink
Alerts None
ID utXXXXXXX0e1
Hardware version rev4_panda_prod2
Software version 2026.04.10.mr77882.1
Uptime 20 hours 46 minutes (Boot Count: 14)
Fraction obstructed 0.648%
Time obstructed 0.00%
Downlink throughput 11.0 kbps
Uplink throughput 66.0 kbps
Pop ping latency 25.2 ms
Boresight azimuth deg -13.6° (desired: -22°, deviated: -8.35°)
Boresight elevation deg 71° (desired: 63.2°, deviated: -7.8°)
@Eddy_Yeung Can we please get this added to 8.6
If we are relying on starlink as our local connection and the dish has a problem connecting either service is disabled, thermal event, obstructions, it’s helpful to see these details locally.
Hi Jonathan,
You are a Authorized Starlink & Peplink Solution Provider, Peplink Reseller, and have yet to discover the Starlink option under the network settings of your peplink to get this information you are asking for?
Its been available since 8.41 version of the firmware.
Enabling the option In starlink wan provided the details that I seek , but only as reported to incontrol2.
It is not visible when logging in locally to the router ui.
Only thing local is starlink wan event in event log.
