Currently if you have an AP managed by a local MAX or Balance device under incontrol the AP is no longer manageable. Remote admin disappears etc.
I’ve had an issue where I need to apply a custom firmware to a set of AP’s in this circumstance, I cannot do this remotely via incontrol either pushing firmware from incontrol (as its under device management) or remote admin and directly (as the feature is removed when an AP is device managed)
On a device you can only push a firmware pack to an AP not an individual custom firmware hence being able to still remote admin from incontrol is useful to be able to do this manually on each AP from there.
To get around the issue I had to setup another MAX router with a VPN to the same Balance the customer was on so I could route directly to the AP’s from a machine, if the function for remote admin was retained under incontrol it would be much simpler.
