Add Extended DHCP Option - 184
I have a customer that is going to be putting Balance 210’s at remote sites, but I need to be able to add DHCP option 184 for their 3Com NBX phone system so the Remote phones connect to the main phone system across a Speedfusion link. I am currently running firmware version 5.4.7, is DHCP relay an option across Speedfusion otherwise?
Joe
DHCP relay is a popular feature request. I believe your HQ DHCP server has custom option 184 configured that as long as Balance 210 supports DHCP relay, then your HQ DHCP server can take care of the rest from there?
We will do defining custom DHCP option in DHCP server. With this feature you can add the option 184.
When will that option be available, this install will be coming up in the next few weeks?
Joe
It will not available very soon. It may be happen in 2nd half this year.
Is there anything you can do before the 2nd half of the year?
Joe
