I’m trying to update the TAG value of Pepwave MAX BR1 device.
When I’m using the “InControl 2 API” site it does the work and I can add/delete TAGs, but when I’m moving to my code I’m getting “INTERNAL_ERROR” as response.
What do I do wrong?
Tanks
What do I do wrong?
Please send your request and conern here - [email protected].
What was the solution here?
I can get it to work from the API documentation page with a data field of;
{data:{device_ids:[1],tag_names:[put-tag-here]}}
But I am unable to phase this in to postman or Ignition Automation successfully. I keep getting the error “MISSING_INPUT”
What is the correct format for postman or another program to pass this put or delete on device_tags ?
Thank You
Ok, I now have it working in postman
Needed to add the data text under the body as raw in the following format;
{data:
{device_ids:[1],
tag_names:[thisisatest]}
Now I just need to get this into Ignition!
