Add "By Application" to Advanced Outgoing Policy Rules Source Selection
currently the only way to create a “By Application” rules is via the SpeedFusion Connect configuration page, however, for the Advanced Outgoing Policy rules there are selections only for IP/MAC/SSID/Client Type (which is fairly useless since client types are usually not reliable)
but there is no “By Application” selection
when implementing this feature, please add it as an additional selector so that we can select both IP/MAC/SSID and By Application
so for example:
Source: MAC
Application: VOIP/SIP (which also needs to be added to the list of applications)
Protocol: Any
Destination: Any
Algorithm: Priority, with highest priority to SFC w/Smoothing and FEC
which will route all VOIP/SIP calls from one computer via SFC
