Add a Range Extender to Peplink SOHO
I have an Amped wireless range extended that I purchased awhile ago to extend wireless to areas in my house with limited or no access. The SOHO doesn’t see this extender and I can’t find any instructions on how to set this up. Thanks for your help.
Wifi Range Extender connects to Surf Soho as client based on my understanding. So no specific setting to be done on Surf Soho. Do you mean your Wifi Range Extender can’t detect SSID from Surf Soho?
Please take note Surf Soho only supports 802.11b/g/n or 802.11a/n.
Thank you - I believe I solved the problem after posting this.
Great! :up:
