Access Peplink balance internal lan from outside using vpn
Hello dear community,I’m new here and I’m new whith the peplink products.
I have a peplink balance 20 where WAN1 is connected to a cisco router and WAN2 to another ADSL router.
The outbound rule is configured with weighted balance algorithm.
I have a vpn configured in the CISCO router who let me connect to internal lan of cisco from outside.
My question is, can I access to a server on internal LAN of the peplink from internet using the cisco vpn ?
Thank you.
For this to work the Cisco needs a static route for your internal LAN pointing to the Balance WAN IP address. Port forwarding is needed in the Balance 20 and you may need to allow access if you have inbound firewall rules configured.
