I need to use AP One in manual IP mode, there is a bug with AP One 300m and Balance where AP does not get IP from Balance in AP Controller mode. So I need to use them in manual mode to make them usable and hope it is stable.
When put into manual mode, the AP is in the same subnet as Balance. The AP is using VLAN defined on the Balance and connected users are getting IP from Balance. However, I am unable to login to the AP from the balance subnet, and only way is to connect directly to the AP via ethernet.
