With the Max Transit Duo Pro, under Signal Threshold Settings, you can set an Acceptable Level for signal strength. When the signal strength falls below the threshold, the connection status box goes red, showing the connection as offline due to being below the threshold.
- Will the connection be restored as soon as the signal strength is acceptable, or does it check using the same frequency as the health check interval?
- If only cellular connections are enabled and both are failing their signal threshold, then if the (default and only) Outbound Policy specifies “When No Connections are Available”: “Use Any Available Connections”, will it use one of the cellular connections despite it failing its signal level threshold check?
