I am unable to to properly configure my Max Br1 Mk2 with 80mhz wifi wan on 5ghz.
Every time I go into the user interface section to configure the drop down for channel width it ALWAYS reverts to 20mhz.
I select 80mhz and hit save, and go back in and the user interface shows 20mhz.
I have tried making the setting when wifi-wan is enabled or disabled and it does not make a difference.
Why am I unable to make that setting stick?
fwiw - i am able to configure the max br1 mk2 local wifi-AP with 80mhz, but not wifi-wan. Also, my target wifi I am trying to bind to is set for 80mhzâŚ
Welcome to the forum @erickufrin
You mean the â20/40/80 MHzâ like in the screenshot below? After clicking âSave and Applyâ, please wait 10 seconds before checking the âDetailsâ. Do other settings have also issues? For example can you set Channel Selection from Auto to âCustomâ and choose some channels just to test (then can revert)? Could you upgrade the firmware to the latest version?
If all this didnât help, you can open a ticket with our Support Engineers.
Hello. I have tried turning on the âroamingâ setting within the wifi-wan screen and that will in fact âstickâ after I apply it. I have also tried modifying the channel width at the same time and it still does not stick.
I have also tried waiting for at least 10seconds to go back in the screen to review. No difference. Wait 1min+⌠same result. Wont stick. I opened ticket # 0010170
Hello Eric, we will follow up with you via the ticket. Our apologies for the inconvenience.
Verified as wrong display of the parameter on the Web Admin UI but saved correctly in the back-end. This will be fixed in a next version of the Firmware.
