7.1.1 Why no DHCP Reservations
Firmware 7.1.1 seems to have removed the DHCP reservations section from LAN…Network Settings. Why? This seems like a fundamentally needed feature…I certainly need it. I had to revert to previous firmware.
Drew VS
Hi. DHCP reservations are still there in 7.1.1. What do you see in the right-most column when you navigate to Status | Client List? Do a “mouse-over” and you’ll see a tooltip that says “Add to DHCP Reservation.”
Yes, I can make one, but where do I see the list of existing ones? That is what appears to be gone.
I’m looking at two routers running 7.1.1 right now and see the existing reservations at Network | LAN | Network Settings | LAN |, then click on the name of the LAN/sub-net. Look at the very bottom of the resultant page. (This is on a Balance router; SOHO would be slightly different.)
I see now, thank you. I only have one subnet so its now buried a level deeper than it was.
You just need to add another subnet to make all worthwhile! :grin::sunglasses:
