5G ROUTER SMA ANTENNA PORTS
That would involve drilling a new hole in the shell or running the 7-in-1 cables through the existing 5-in-1 hole, which is very difficult from what I’ve gathered. I’m looking for a compromise solution. :slight_smile:
Hi! I’m curious what solution you came up with. I too have and AS (2025 Trade Wind) with the prewiring for AS Connect. I’m looking for a solution to use the wiring with a modem and antenna I purchase myself. From what I understand using a new antenna requires running the wires in place of the preinstalled wiring?
Thanks, Chris
We work with Airstream upfitters and dealers and the solution for this is consistent across the board: remove Airstream antenna and install a proper 5G antenna and router :slight_smile: It sucks, but that’s how to get it done. You can’t use 2x2 on a 4x4 radio with good results unless the radio understands that’s what you’re doing, and the current versions do not.
I got a Parsec Akita Lite antenna and that has worked well in 95% of the places I camp. I
