450 Mhz Supported Hardware?
Have been searching the forum for info but not much to be found…
Does peplink have any products that support the 450mhz band or specifically any of the following LTE bands? Band 31,72, 73, 87, 88?
@Wiktor
Would you please contact Peplink local partner and send in the request for the requirements ? Those bands not seen like ordinary commercial bands. It will be more easy if we can have more info for the projects that you are currently working on instead of discussing the bands info only.
Will contact them to see if there are any possibilities.
We are testing some lower fq equipment on scandinavian commercial bands but unfortunately the supplied hardware lack both finesse and quality. Would be interesting to integrate these into our already existing peplink setups.
There are more and more private LTE / hybrid public network deployment to support B31 in Asia. pls consider to have a B31 capable router for utilities
