4 Active Sims + Speed Fusion Connect
Does anyone know how a Transit Pro (Duo) would react with 4 active SIMS and Fusion Connect Active?
In what way react?
The Transit Pro (Duo) has 2 cellular modems, so at max you can use two active SIMs at the same time, the other will be used in fail-over or however you configure them to operate.
Speed fusion connect is treated like having a third sim slot for each modem.
You can choose if you want to connect A/B/SFConnect
So will it round robin all three trying to find a signal?
