Can someone tell me if this most recent firmware update is supposed to allow you to be able to forward the starlink POS(GPS) data into one or all of the vlans in the router? If so, what would the proper config be using putty (or any other device that can except this string) I tried doing a forward to a computer’s ip address. with a port number. then in putty i entered the routers gateway and the correct port but I’m only getting refused connection errors. Thanks in advance for any help.
