We highly discourage purchasing used Peplink devices. Peplink cannot guarantee the source or quality of these devices, it may also put you at risk.
What is the risk of purchasing a used Peplink device?
We cannot verify the source or quality of the used devices, and will not be able to determine if the device is obtained through illegal means or if the hardware has been modified in any way.
There are cases that the used device may still be registered with its previous owner and is still connected to their InControl 2 organization. Your data may be accessible by the previous owner.
Why can’t I access InControl 2 with used devices?
It’s possible that the previous registered owner hasn’t cleared their record and the used device is still registered with its previous owner.
Can I request Peplink to release the device from the previous owner’s InControl 2?
Due to security and privacy concerns, Peplink cannot change the InControl 2 registrations on behalf of the original owner.
If I can’t use InControl 2, how can I configure my device?
You can still log in to the device via Web admin. If you are using MAX series products, you can open a web browser and enter the router IP address https://192.168.50.1; for Balance series products, the IP address is https://192.168.1.1
I purchased a used Peplink device and cannot register to InControl 2, what should I do?
If you are able to contact the original owner, you can request them to remove their registration in InControl in order to register it under your name. More information on removing devices from InControl can be found here.
However, even if you can’t reach the original owner, you can still configure the device’s settings via web admin.
We still highly recommend that you return the product(s) to the seller or point of purchase and obtain a new device from our certified partners.
So I shouldn’t buy used devices, then where should I buy Peplink devices?
You can purchase official Peplink products globally from any of our certified partners, listed here
