20/30 6.1.0 Public Beta 1 build 2422: 2nd hard crash in a week!
#1
Since installing the beta I have experienced my second router crash in a week, which can only be recovered by powering down from the mains.
It stops serving ip addresses, cannot log into the GUI.
It seems to occur when I attempt to change a WAN port’s setting from PPPoE to Static ip, in order to access a modems configuration.
The Peplink 30 was previously the most reliable router in my experience.
It has never crashed or stuttered in >18 months of heavy use.
I hope you can work out the glitches, as I am considering reverting to the previous non-beta firmware.
#2
Can you send us a diagnostic report of this case with 6.1 beta firmware by creating support ticket? Then, we suggest to revert back to 5.4.9 firmware. We will inspect the case internally.
#3
Thanks, I have submitted a diagnostic report as advised. I am now reverting to the previous firmware.
#4
Mine crashed today. Weird though. The DHCP server was down. The webserver admin was down too. traffic was passing for connected devices with IP addresses and cached dnS
#5
Hi Dan,
Please open support ticket and submit your diagnostic report so we can investigate.
-Jonan
-Peplink
#6
A new beta firmware will be sent to you through our ticket system, which should solve this issue.
#7
I have a same problem.
#8
Hi astryukov,
A new beta firmware has been sent to you through our ticket system. Please have a try. Thanks.
#9
hm, I can submit ticket but I can’t login and respond or see my open tickets.
#10
@astryukov: We have discussed and dispatched the firmware over our support system
#11
#12
Please make sure support@peplink.com is whitelisted so you can receive responses and updates.
#13
it is white listed, I did received reply that firmware was:
Hi astryukov,
but i never got link to firmware download or I’m unable then I login to secure.peplink.com see any of my open tickets. Such option simply doesn’t exist there.
#14
I gave experienced three crashes of the web ui after pressing “apply” - have to power cycle router to get access again, could I try the new firmware please?
#15
Dear all, we are still improving this area, and we will send you all another and newer firmware. We will also update you once the firmware is available.
#16
As my previous post in here, we are working on another new firmware, and we will send it to you via email.
#17
On a related issue, I managed to lockup the web GUI, forcing me to pull the power and a reboot.
I was in the support.cgi screen with packet capture active, with a regular screen in another browser tab where I pressed Apply changes, and it locked up. The change I made was to activate the ipsec vpn connection.
#18
I haven’t got a clue where to do this. I got an account on the store thinking it was support. Registered a device. Cannot see anywhere to submit a support ticket
#19
Support tickets can be submitted here:
http://cs.peplink.com/contact/support/
#20
Cheers, done it now
