PMed you to gather more info and see what we can help for your upcoming project.
@MartinLangmaid, @mldowling, @Rick-DC and other fellow partners
As promised by Engineering team, the test firmware for LAN NTP server feature is ready for partner. You can download the test firmware using the followings URL:
As for now , the test firmware is only available for the below device models that having RTC Chipset (RTC - Battery powered time storage to keeps time running even router is power off.):
NTP Server Test firmware (8.0.2s052):
Balance One/Balance 210hw4/Balance 310/MAX BR1 ENT/MAX Transit/MAX 700hw3/MAX HD2 mini/MAX HD4(Edited : 21/02/2020):
https://download.peplink.com/firmware/plb1/fw-b1_210hw4_310hw4_br1ent_transit_m700hw3_hd2mini_hd4-8.0.2s052-build4438.bin
B210_310hw2hw3(Edited : 21/02/2020):
https://download.peplink.com/firmware/plb310/fw-b210_310_hw2_hw3-8.0.2s052-build3672.bin
B305hw2/B380hw6/B580hw2/B710hw3/B1350hw2/B2500(Edited : 21/02/2020):
https://download.peplink.com/firmware/plb2500/fw-b305hw2_380hw6_580hw2_710hw3_1350hw2_2500-8.0.2s052-build2747.bin
EPX/SDX/MBX (Edited : 21/02/2020):
https://download.peplink.com/firmware/epx/fw-epx_mbx_sdx-8.0.2s052-build1438.bin
SpeedFusion Engine Cam (Edited : 24/02/2020):
For the above firmware, default NTP server is enabled for the device LAN interface. As for now, we have no WebUI that allow to enable/disable the feature. If the feedback from our fellow partners is good, then the feature will be roll out for the next general release firmware including the option to enable/disable the NTP Server service.
This work speaks very well of Peplink and its responsiveness to usersā and Partnersā requests. Thanks very much. Weāll check it out.
i have a customer looking for this feature in the MBX. Would it be possible to get a Test firmware for this model also.
Thanks in advance.
Engineering team is checking on this. I will update again when i get the latest update for the team.
I too would be interested to see this implemented for customers with the Balance 20, as I was the one that started this topic. However since Iām no longer under hardware warranty I donāt see that happeningāfor me at least.
/Marty
Device firmware is opened for download without referring to device hardware warranty. As long as your device hardware version is compatible then you can upgrade your device using the latest firmware and enjoys the new features. You can get all the archive firmware here : https://www.peplink.com/support/downloads/archive/
I think the main problem here is the lower end models & old hardware revision and this is not concurrent considered available for the devices.
Hello @sitloongs,
We are looking for some deployments to test this out in the field.
What are the sources for the routers NTP server?
What is the order of preference that these sources are used to reference the routers internal NTP server?
We want to set up as prefered order of sources the following:
- Time from GPS
- Time from Cellular Network
- Time via serial input (used Evertz previously Timing & Synchronization | Solutions by Product Type)
- Time from WAN source via NTP
- Time from LAN source via NTP
- Time from SpeedFusion source via NTP
- Time from internal router clock
Others colleagues here will have their preferences.
We realise not all models will be able to do all of these options due to the equipment features such as with the GPS, Cellular & Serail plus available system processing.
Overall this is great to see. We will be going back to previous leads weāve had with this GPS feature.
Happy to Help,
Marcus
As for now , the LAN NTP service will work as below:
Client devices ā LAN NTP ā System Time (Router)
System time have 2 sources:
System (Router) synced with External NTP server
- Depend on System Time Server settings : LAN/WAN/SpeedFusion
For you requirements above, please send me your project info and we can discuss what we can help for that.
As previously posted earlier in this forum thread.
Happy to Help,
Marcus
Thanks team! This will help alot.
Yes, itās definitely impressive to see a company focus on quality, good pricing, solid support, and all that while implementing a lot of requested features.
Much respect!
Hello @sitloongs,
The recent 8.0.2 GA release does not appear to contain the new NTP server feature?
Testing on the NTP server within the router so far has been useful. We would like to see the NTP Server become a standard of future releases. Is there a release available with the NTP Server with 8.0.2 ?
Happy to Help,
Marcus
As for now the NTP server firmware still in testing phase. I can definitely check with Engineering team whether we can release a test firmware for 8.0.2. Please stay tuned.
@sitloongs
Could we get a firmware for the BPL-380 with the NTP over LAN we need this for a deployment.
PS: The firmware we had for the MBX is working like a charm with NTP over Lan! Customer is really happy with it.
Thanks in advance.
Any chance the NTP server option will be available on the MAX BR1MK2? With the built in GPS allready there it should be easy. I have some time sensitive apps that I need to be able to keep synced to an accurate clock
As for now, the NTP service will update base on the followings. BR1 MK2 are not in the list .
we need the firmware for the BPL-380 for another customer. Would it be possible to provide this?
